APX8000
Sarcastic Member
Do they both have voice buffering enabled ?
Are they listening to the same tower/site?One thing I notice is when I have my G4 and G5 on the same P25 NJ ICS system there is an echo between the two as if one is slightly behind the other when receiving. Don't recall this prior to this firmware. Related?
Same site yes.Do they both have voice buffering enabled ?
I don't have any message playback cutoff.And of course the end of transmissions are still cut off on message playback. Why? Super annoying.
Here is a short video of the message playback:I don't have any message playback cutoff.
I am not doubting you or anyone else, I am merely stating that I haven't had these issues with my pager. This leads me to believe it may be a setting somewhere.Here is a short video of the message playback:
Dropbox - 20190324_204409.mp4
The most noticeable one was when the dispatcher said "you can dis..." (...disregard).
Also I'm not the only one with this issue...
https://forums.radioreference.com/threads/g5-recording.360529/
My vote is to update.So what is the consensus, update or not?
The recording in your video is terribly broken up. My recordings have always played clearly and completely, exactly like the original transmissions.
@ Floridarailfanning. That happens after new updates for PPS when you have OFF DUTY listed in the controls AND or ... TONE isn't selected in your Zone set-ups individual talkgroups. The alert MODE is the thing that changes it from muted to sound for every talkgroup in step #4 in the PPS AND in a ZONE in step#5 when you look at the bottom for a drop down box, can't be set to "off" has to be TONE.
A well known thing from 2 firmwares ago. Discussed here
https://forums.radioreference.com/threads/g5-pager.362615/
Question - I changed all tones to Default for all TG's - now each transmission i have a loud tone - how do I mute the tone - but keep the audio ? Thanks for any further tips ... I just did the Firmware update myself.
