Good Morning, All:
I'm moving up from the small (but mighty) EX600XLS to a much-larger (and mightier) XTS5000.
I have the EX's emergency button programmed as home-channel revert (personality 1, channel 1), and I'd like to program the XTS the same way. Problem is that I can't figure out a way to do that. The EX was easy: there's an option for doing just that right in CPS. If the XTS can do that, I don't see it in Astro25 (v20, if that matters), or it's not as obvious. I realize that with the mechanical hard-stop that the XTS has for channel 1 on the selection knob, rather than the un-stopped EX, having the button programmed to revert isn't as necessary, but I like having the option. This is all under Conventional personality; we're not trunked/encrypted/talkgrouped/anything advanced.
In case anyone asks:, this is my personal radio for the volunteer fire department, my department does not use/have use of the emergency button, and the Chief is ok with my programming it this way if I can.
Thanks very much!
Thanks very much!
