Mine is the Scanner version, but to be honest I don't know if there really is a difference.
Middle of the roof are always suggested as the best placement for an antenna.One thing I have found -- at least in my experience -- is that the COMPACtenna definitely does better in the middle of the car roof, and not in the corner like the product literature says...not sure why that is.
I know middle of the roof is optimal...I was rhetorically asking why when the COMPACtenna product literature says corner of the roof is best it actually works best in the traditional center roof location (at least the two models I've had anyway).
Okay, I guess I'll step into this lions den. Ordered the 2m/440 version from Universal Radio. Wanted to be able to drive into the garage without having to remove the antenna. It arrived early this morning so I've been putting it through some tests.
First test was conducted with the Yaesu FTM-100DR that is currently in my vehicle. I could not detect any difference in the antennas performance and the Laird 1/4 wave I had been using. I could only measure SWR on VHF since I do not have a meter capable of UHF. (I don't really use the UHF side except to monitor the local VFDs.) SWR on VHF hovered around 1.8 throughout the band. Totally acceptable for my intended APRS use.
Now for the scanner test. Used the Whistler 1098 I use in my shack to monitor the Montgomery P25 and AFRN systems. Connected it up in the car and was pleasantly surprised. With the car in the garage the scanner locked on to both systems control channels with 3 bars signal strength. AFRN was not seeing much use, so I turned that off. The scanner tracked the Montgomery system and I could hear the radio traffic clearly.
Taking the car for a ride was even better. Once outside the garage the signal bars were a full 5 and I had no problems following the conversations. I was only monitoring the Bald Knob and simulcast sites.
Now I have to decide which radio to have in the car.
I don't really understand the physics behind this design, and really don't care, but the antenna works.
If possible test the Compactenna against another so we will know its better or worse than brand or type X.
Well that didn't last very long. Went to the Mall last night and was inside about 40 minutes. Came out and the Compactenna was gone. Someone stood in my truck bed and removed it from the NMO mount in my roof. It was on pretty tight so I know it didn't just come off.
I've had one or more antennas on my truck for 10 years and have never had a problem before.
PS - k4EET, haven't seen you around lately, hope all is well, brother.
Well I have ordered the COMPACtenna SCAN III scanner antenna comes in 5/18/2019 I will test next week and see how it works in my area.
