When I try to open FMPA-CC.bat or FMPA.bat it won't open window closes too fast.
You run one using -i20001 the other using -i20002, you get voice from both at the same time (which can get confusing)
I have not tried running both into one of them but I will give it a try.
(OK it grabs one of them and ignores the other)
Yep. Out of curiosity I also tried putting the two FMP24s and one DSD+ on the same TCP port number. I didn't expect that to work and of course it didn't. This may be an addition/problem for a future update to address.I tried it. You get all the audio. You can also direct each copy of DSD+ to a single speaker with -o<num>L and -o<num>R.
This is what I get. I madea fmpa.bat and put in FMPA -i1 -o20001 -f452.0 (using 1 dongle)
C:\Users\End User\Desktop\DSDPlusFL>fmpa -help
FMPA 2.29
Current working directory is "C:\Users\End User\Desktop\DSDPlusFL"
Airspy serial number list: -none-
Spectrum window width: 1024
FFT size: 32,768
Spectrum update rate: 10 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 25.000 100.000
DSD+ path is "C:\Users\End User\Desktop\DSDPlusFL"
Primary frequency list: '.\FMPA-FreqList.csv'
Secondary frequency list: '.\FMPA-FreqList2.csv'
Database search distance: 99.90 miles
Base latitude/longitude: 19.7163 -155.6241
Usage:
FMPA [options] Normal operation
FMPA -h Show help
Options:
-i<num> Airspy / Airspy Mini device number (1-255) [-i1]
-o<num> Output audio device (1-255) [-o1]
-o<port> Output audio TCP port (256-65535)
-L<num> LNA gain (0-15) [-L15]
-M<num> Mixer gain (0-15) [-M15]
-V<num> VGA gain (0-15) [-V10]
-T<num> Enable/disable bias tee (0-1) [-T0]
-f<MHz> Initial tuned frequency [-f99.9]
-b<kHz> Initial filter bandwidth (4, 7.6, 9.5, 12.5, 22) [-b7]
-u<num> Enable/disable unlicensed spectrum display (0-1) [-u0]
-z<num> Show zoomed spectrum (0-1) [-z1]
-n<num> Select noise filter (0-2) [-n0]
-v<num> Set volume level (0-500) [-v100]
-s<num> Enable/disable scanner mode (0-1) [-s0]
-wsl<v>.<h> Spectrum window location [-wsl50.50]
-_<num> Minimize windows at startup; bitmapped
-rc Role is trunk control/rest channel monitor
-rv Role is trunk voice channel monitor
Active keys:
0-9 . Enter set frequency
[/] select step size
Cursor </> step frequency
Ctrl Csr </> step frequency by 250 Hz
U toggle unlicensed spectrum display mode
M toggle spectrum memory overlay
X reset spectrum memory
Z toggle spectrum zoom overlay
I select injection mode
b/B select bandpass filter
F select noise filter
Cursor ^/v adjust volume level
spacebar toggle muting
j/J adjust LNA gain
k/K adjust mixer gain
l/L adjust VGA gain
R toggle raw I/Q and FM demod recording
S start scanner mode or exit hold mode
C start trunk control/rest channel following mode
V start trunk voice channel following mode
? list active keys
Esc exit scanner/CC/VC modes or exit program
Left click on spectrum: retune
[CODE]
It looks like the config file being called is not in that folder. I think you may need to do the standard DSD+ install, I think it's 1.101 or something similar from their website, dsdplus.com, and then overwrite with the Fast Lane files
Post your FMP24.cfgI went back to 2 versions of DSDPlus and copied and pasted the fmp24.cfg and still get the same error.
Looks normal. Are you using RSP?2.4 ; sampling rate (1.0, 2.0 or 2.4)
1024 ; spectrum window width
64 ; FFT size (16k, 32k, 64k)
10 ; spectrum update rate in Hz
5000 -6250 7500 12500 15000 25000 ; step size table; units = Hz; negate default
. ; DSD+ path
.\FMP-FreqList.csv ; primary frequency list CSV path\filename
.\FMP-FreqList2.csv ; auxiliary frequency list CSV path\filename
miles ; search units (miles or kilometers)
99.9 ; search distance
19.7163 -155.6241 ; search origin
thanksrtl 2832u r820t2
Are you wanting single dongle usage?View attachment 70874
here are what files I got now
Why are you using FMPA with an RTL dongle?rtl 2832u r820t2
Single if possible.Are you wanting single dongle usage?
I've tried fmp24 or fmp nothing comes upWhy are you using FMPA with an RTL dongle?
