WebsterEMA
- Joined
- Sep 15, 2017
- Messages
- 36
Howdy. I'm broadcasting 2 feeds from one of the computers at my job. I'm using RadioFeed v4.2 software. It's worked great for months, but in the last.. Month or so I'd guess, one feed will just stop. I'll get an email saying feed is down out of the blue. When I get to the building, one is working fine, the other I just have to click cancel or disconnect, then connect and it starts right back no problem.
It's not one particular feed. One time it'll be feed A, the other it might be feed B.
Going back through the logs, you can see both feeds getting a "Source Client - Boradcastify Timeout" message at the same time.
Then "Source Client Disconnected"
The client that continues broadcasting will then spend a minute or two showing
"Source Client Started To Connect To A Broadcastify Server"
and
"Source Client Unable To Connect To A broadcastify Server"
until finally settling on
"Source Client Connected To A Broadcastify Server"
The other one, after the disconnect, never tries to reconnect. I'm not sure what's interrupting both feeds at the same time, and I'm not sure why one won't reconnect, and the other does. Auto Reconnect (10 sec.) is checked for both instances of the program.
Is there any advice anyone can give? Some troubleshooting steps to try and figure out the problem?
and
