Is there SDR software out there that will work with a NooElec to allow one to scan like a scanner?
Sdr# works with the rtl chips just got to install the right drivers. Windows installs a incompatible driver and it has to be replaced. The last time I downloaded SDR# in the zip file was a file to install the proper drivers I believe it was a .bat file.Find the instructions for installing the Zadic drivers - and you will be up and running fine on SDR# - SDRSharp is a good software to start with.
this is almost exactly what I did (save I didn't listen for a 200hz PL tone), and then I switched over to just RTL_TCP from a openwrt AP that is lightly loaded and stream the I+Q to my LAN so any of a half dozen GNUradio apps, SDR#, phone apps can access it locally and I can pick and choose.i use RTL_FM and you probably already have it
it can scan many different ways
it will even scan SSB
i pipe the audio to SOX to give it a 200Hz PL tone trim then off to Pulse for play back
like
rtl_fm -M fm -d 1 -p 69 -f 45.4400M -f 151.0550M -f 151.2800M -f 153.7400M -f 153.7700M -f 153.8300M -f 153.8450M -f 153.8750M -f 153.9950M -f 154.2950M -f 154.3400M -f 154.4300M -f 154.7550M -f 155.0400M -f 155.0700M -f 155.1450M -f 155.1600M -f 155.1750M -f 155.2800M -f 155.2950M -f 155.3400M -f 155.3700M -f 155.4000M -g 30 -s 11025 -F 0 -l 70 | play -v 1.5 -t raw -b 16 -e signed -c 1 -r 11025 - sinc .2k
actually I am using SOX to do a 200Hz highpass filter so I dont have to listen to the PL tonesthis is almost exactly what I did (save I didn't listen for a 200hz PL tone)
Answering your original question, I'm working on scanner software for SDR dongles. It's in Alpha though so it's buggy, but I plan to announce it publicly in the coming weeks
That sounds like quite the challenge! Good luck!Answering your original question, I'm working on scanner software for SDR dongles. It's in Alpha though so it's buggy, but I plan to announce it publicly in the coming weeks
it was quite a bit of tinkering to get it to do what I wantedstrong work
