gman66
Hi I have a Radio Shack Pro 652 scanner. It was working just find and now can not receive any thing but he weather.
Here goes... I have a RS Pro652 scanner. Used it for a long time but gave it a break for a few years. In the mean time Maricopa County and Agencies have changed frequencies. I erased all the prior db I had installed but now have no idea what or how to install a new db. I did read somewhere the new Maricopa County/MCSO db should work in the 652. I am considering a qualified programmer in the NW valley.
If you are in Berlin MD, Ocean City, Worcester Co, and the FIRST statewide system are all P25 Phase 2 which the Pro-652 cannot receive. The 652 is capable of Phase 1 only.Hi I have a Radio Shack Pro 652 scanner. It was working just find and now can not receive any thing but he weather.
I did find the Maricopa County AZ db. It is P25 II. I now own a $400.00 Radio Shack brick. Thank you for your help.You might want to inquire in the Arizona section of the forum. I'm not familiar with Maricopa County, if they moved to Phase 2 or encrypted. In either of those two cases the PRO652 will no longer work. Have you looked at the database?
