So I have a boafeng radio that I am going to use for my EMS job in Lehigh county. I programmed the frequencies and when I key up the radio I hear myself in the truck and company portables but County Control does not hear me how can I correct this issue.
1822,
Sounds like you have a programming issues.
As for the comments above, let me explain some of them, maybe that'll help.
1. BaoFeng radios are very low end radios designed for the hobby crowd. I'd not ever use them in any sort of life safety application. There's a liability issue that that I'm sure you can understand. Just like you wouldn't buy your defibrillator from the cheapest place you can find in China, no one should be using $20 Chinese radios in
any sort of public safety application.
2. Federal Communications Commission rules are very clear on the subject. All radios used in these sorts of applications
MUST have a valid Part 90 certification. Some of these low buck Cheap Chinese Radios either do not have those certifications or have fake certifications.
3. The FCC is also abundantly clear in 90.427, it is the responsibility of the licensee (agency/person who's name is on the FCC license) to maintain 100% control over every and all radios on the system. That very specifically means that you, even as an employee of the agency, is not allowed to add a radio on to the radio system without express permission from the licensee. It doesn't matter if you are an employee, a volunteer, your supervisor said it was OK, or anything else. Without express permission from the licensee you are operating without a license, and both you and your employer would be in violation of those rules.
eCFR — Code of Federal Regulations
You may find someone that will gladly help you get your radio programmed correctly, but PLEASE, understand and abide by what was said above. Do not put anyone's life on the line with a $20 radio. Make sure you get permission (in writing on agency letterhead) from the agency holding the FCC license.
Better yet, just use the radio for listening. No issues with that.
I run/maintain public safety radio systems for a living. I'd —never— use one of the cheap Chinese radios in any sort of professional/public safety/life safety application. I've had users try, and they always sound like crap, and the dispatchers complain to me of "radio system issues". The time wasted tracking them down and getting a proper radio to replace it is costly. Don't be "that guy".
