Harnett County, NC on G5
ccfire918
I have Harnett county programmed into my g5 but cannot receive any traffic other than “Fire Response”. All TGIDs are programmed for the Tac channels but nothing is being received for those. According to RR they are not encrypted. All CC are programmed as well as towers. Anyone have any insight as to what the issue could be?
CM1
Central, NJ
How many (and which) specific sites do you have programmed, also double check your WACN and System ID are programmed correctly.
ccfire918
I have my 2 county viper sites(Johnston) and a few Harnett sites because I work near the county line. As far as I know WACN /Sys ID and sites are correct per RR
CM1
Central, NJ
You might want to try this...
Set up one of your G5 zones (lets assume you're going to listen at your house) to only use one site that is closest to your house. (Don't add any other sites). Set it with TG's you want to scan etc...
I'm not too familiar with VIPER, but maybe with too many sites added to your system, the G5 could be locking on to one of the other sites before the one you actually need. The problem is "the other site" may not host radio traffic for your particular area. Hence you hear nothing, except maybe an areawide or statewide talkgroup stuff only. I hope I explained that right? LOL
N6ML
As @CM1 hints; it's typical for talkgroups (especially things like tac channels) to only be carried on sites where they are needed, on these large regional systems. For example, the channels for a city fire dept would only be carried on sites serving that particular city.
KB4SHP
I am using a g5 on viper I have found if you are trying to hear certain talk groups in a county just program it couple of sites for example I live on north side of the county and fish on the south side will I program just the 2 sites that are on the north side so I can still hear the northside will on the south side. You got to remember the g5 works like a radio it doesn’t scan all the sites it locks on to one and it holds on that site until the signal is lost
ccfire918
I reprogrammed like mentioned above and made sure all was correct, but still nothing. In fact, now it doesn’t lock onto any site, it says out of range... inside the county fo
ccfire918
I think my reply got messed up.... doesn’t lock into any sites in the county I’m in now and it’s programmed for those towers. It says out of range. I can receive everything fine on a pro-668 scanner but not g5...
IAmSixNine
Dallas, TX
Make sure the RFSS and Site info are in HEX and not DEC.
Then make sure your using the matching control channel (and alternate control channel) for the correct site your programming in.
To test this out set the knob position as Trunking TG monitor. this will pass all audio on the site. If this works, then you can modify it for the TG you want to hear.
Is the agency you want to hear geographically close to the tower you are picking up?
