I have tried doing this on my scanner as a conventional, it dosent pick up all the time, and there is encryption sometimes too. I have a whistler WS1040
What site on the Interagency Communications Interoperability (ICI) system is closest to you? What programming software are you using?I have tried doing this on my scanner as a conventional, it dosent pick up all the time, and there is encryption sometimes too. I have a whistler WS1040
I program on the scanner and sometimes Win500You will need to learn how to program a trunked radio system (TSYS) in the scanner. Programming a trunked system like a conventional frequency will lead you to hear everything on the radio system because the scanner has been setup in a way that it cannot select a talkgroup to monitor. Are you programming your scanner by hand or with some sort of software?
