DCS question
bharvey2
That doesn't make a lot of sense. DCS usually refers to "Digital Coded Squelch" a digital analog (well, that sounds ridiculous doesn't it?) to the PL tone. I think that MURS only allows for analog emissions. Not sure where "digital" fits in but maybe the FCC has changed rules regarding MURS. Or more likely, they're just being ignored.
poltergeisty
Truth is a force of nature
RLG, Fly heading 053, intercept 315 DVV
So in column 4 and 5 you can set a CTCSS or DCS tone, but in column 10 that I pointed to there is an additional option for DCS encryption. It is that option I'm confused about. I've never seen such a thing or even heard of it before. I don't think it's for voice encryption since it says DCS encryption. Or am I wrong? I don't recall seeing these radios on eBay advertised as having voice encryption and I don't even think that's allowed on MURS.
I searched on the Internet high and low for any information about encrypted DCS, but found nothing. If it really is encrypted DCS, I wonder if it's actually an XOR of the DCS tone or something.
Thanks for the help thus far. I'm really interested in what this is. The radios should be here today and I'll run some tests and see what my scanner records with a DCS squelch on and then using the so-called encryption option.
jonwienke
More Info Coming Soon!
VA
Its probably a mistranslation of DCS inversion, in which all the bits are flipped.
poltergeisty
I thought that too, but the invert DCS codes are there in columns 4 and 5.
I got the radios yesterday, but the programming cable I have is RS232 and I don't have a serial port on my commuter. Though, I do have a serial port PCI-e card, but I'm not pulling my PC apart to add it. Major PITA. I think I do have a USB cable though. Not sure. If not I'll order one. Then I can see what this option really is.
kv5e
T¹ ÆS Ø
Baseband processor for many of these CHICOm radios has an inversion scrambler built in. It has three bits to select the carrier frequency of the balanced modulator, if the selections are limited to only 8 values then it may be settings for inversion scrambling.
bharvey2
Inversion style "encryption" is what I suspect it is too.
bharvey2
I think the "I" after the number (e.g. D023I) refers to inverted which is alluded to in the posts above. My guess is the DCS Encrypt refers to some form of encryption, most likely voice inversion scrambling. As I recall, it has a distinct sound. You could probably Google it for an example.
bharvey2
Yeah, I know what it sounds like and have a program to decode it. I don't know why they call it DCS encrypt though.
My guess is that it's just a matter of poor translation or the programmers having insufficient knowledge of how the radios work.
nd5y
Wichita Falls, TX
Did you do something simple like program the same frequency in two channels and set one with DCS Encrypt ON and the other with it OFF and then listen to both on another radio or scanner and see if there is any difference?
poltergeisty
Well, got the cable today, installed what I think is the correct USB driver and nothing. Radio won't identify on the computer. So I can't see what this option is until I can get the radio to ID on my computer. So I'll be creating a thread on that.
