Every Monday, I run the update and upload it. I ran it again last night and was able to get some SDSO chatter but it wasn't clear kind of broken up digitally if that is the right description. I help out with our local brush fire party line group on facebook and was hoping to get it going again.
That issue isn't unique to the 436, it's a problem with every digital scanner model ever made except for the SDS models, which are designed specifically to handle simulcast and multipath reception.There is another issue the 436 has when it comes to trying to receive simulcast sites where the signal coming from 2 different sites is not perfectly in phase and the scanner gets a little confused, basically, trying to decode. Try moving the scanner around to find the clearest spot -- that usually help.
Have you tried comparing the performance of the SDS200 and 536HP while mobile in a simulcast area?
If you're having reception problems with a SDS, the problem isn't simulcast.
Let's start with the basics. What are your RSSI and NOISE readings on that system?
