thorosaurus
- Joined
- Feb 10, 2020
- Messages
- 61
In other words, if someone has a VHF/UHF radio, can they access all of the itinerant frequencies, or are there some on other bands?
Where can I find a complete list of those? I've tried googling, but all I can come up with are the ones on the VHF UHF bands.No. There are itinerant freqs everywhere from low band to 900MHz.
Did you actually read the notes on the page @jonwienke linked? Seems not, as the answer to your question is on the page.Okay, so the reason I'm asking, people said that the Motorola MTS2000 800 mhz radios being sold on ebay right now couldn't be used commercially. But it looks like those radios can do 806-870 mhz, and it looks like there are itinerant frequencies within that range.
What am I missing here?
I did. But then I followed the links at the bottom to the longer list.Did you actually read the notes on the page @jonwienke linked? Seems not, as the answer to your question is on the page.
Okay that makes sense. Maybe put a note next to that link though warning new guys that the list on that page hasn't been updated to reflect that.I'm not sure what exactly you're referring to, but I feel like this was beaten to death in your other thread. There are no remaining itinerant frequencies in the 800 MHz spectrum. There was one pair prior to rebanding (808/853.4875), which is now allocated to public safety.
I do have a legitimate business interest, so that's no problem. Also don't mind sharing the frequencies. Given the inherent wattage restrictions and the rural nature of my area, I don't expect there to be any interference.Note too that use of itinerant frequencies still requires a Part-90 FCC license. These allocations were intended to provide radio communications for companies and other entities that have a need to use their systems over wide areas, statewide, and even multi-state. These frequencies do not require coordination and are used on a shared basis.
Which link/page specifically?Okay that makes sense. Maybe put a note next to that link though warning new guys that the list on that page hasn't been updated to reflect that.
This one.Which link/page specifically?
Business frequencies are not the same as itinerant frequencies.This one.
Electronic Code of Federal Regulations (eCFR)
Electronic Code of Federal Regulations (eCFR) published by the Government Publishing Officewww.ecfr.gov
If that's supposed to be a table of business frequencies it still has 854 to 869 listed as being okay. And if I understand correctly, you guys are saying the FCC gave those to the police?
Now I get it.Business frequencies are not the same as itinerant frequencies.
Business frequencies = eligible for fixed and defined area of operations licenses. Typically afforded some level of frequency coordination.
Itinerant frequency = licensed for use in a large area, with no one particular place more often than another. Not usually coordinated ahead of time.
