Kenwood NX-3200 Two Tone Issue
rockinromac1
Southwest Harbor, Maine
Hello all, I'm having a issue with Two Tones. I am trying to get the same radio to page for 2 departments which one uses a two tone and one uses a long tone. The first departments tones work fine and it activates fine. The second departments tones do not activate the radio. If I put the second Departments Long Tone in the twotone1 slot, it activates fine. I am trying to get it to activate while scanning and the tones should be plenty long for it to activate while scanning. Any help would be appreciated. Thank You!
Scan and two tone paging don't always work well, even with long tones.
Also, there are some Motorola two tone setups that use really short length tones and some other brand radios will have trouble decoding those.
Try putting -just- the agency that uses two tone in there and see if it alerts.
rockinromac1
The department that uses the 2 tones is the one that is working correctly. Im having the issue with the long tone department. Total the long tone is about 8 seconds so I doubt that that is the issue.
Just a idea, is it possible that the radio only looks for the page on the selected channel?
OK, I missed that in your original post.
I don't have my laptop here at home with that software on it, so I can't look it up. It should decode if the receiver picks up the correct tone. Scanning is often an issue with 2 tone paging or even things like MDC or DTMF since it can miss the first part. A long single tone should work if it's programmed correctly.
rockinromac1
Ok, I just did a test for Tone Test. Selected the channel that wasn't working before and turned off scan. The tone alerted as it should. Anyone have any ideas or want any screenshots of any pages in the software?
