You are very fast, I really appreciate your help. If I can manage the 1.10.00 update. Will I need to do updates before 1.10.00 or can I update them all ....
.Thank you very much for your help. I could not find the place you said. If I ask, can you send a link.
[QUOTE = "fxdscon, gönderi: 3438346, üye: 101354"]
Tüm güncellemeleri yapmanız gerekmez, sadece en yenilerini yapın.
[/ALINTI]
Ben tam olarak ne dediysen onu yaptım. ve cihazım güncellendi. Ne kadar mutlu olduğumu söyleyemem. Sds1oo'yu tanıtmak için daha yeniyim. Öğrenecek çok şeyim var. Size ve yardım etmeye çalışan arkadaşlara bir kez daha teşekkür ediyorum. Harikasın. Sağlıklı kal. Herşey gönlünüzce olsun. Oyuncağımla biraz daha oynayacağım.
TA4LMK 73
.[QUOTE = "fxdscon, gönderi: 3438346, üye: 101354"]
[/ALINTI]
TA4LMK 73
I will get a new Sd card and try it soon..
I'm happy that you were able to get your scanner updated.
It is still a mystery why the scanner would not update using the Sentinel software.
If any other unusual problems occur, it could still be a faulty SD card.... sometimes an SD card that is failing may only affect 1 or 2 things.
I'll write the results to you. What has changed on my device with the new update ..
My guess are that the inofficial beta firmware could not be properly handled by Sentinel to determine the version number.It is still a mystery why the scanner would not update using the Sentinel software.
I did not get the device to zero. I bought it from second hand. It can be as you said. Sensible What should I do.? I could not get a Sd card yet due to the intensity of my work. I had no chance to try it out ... Thank youMy guess are that the inofficial beta firmware could not be properly handled by Sentinel to determine the version number.
Can't see that the SD card can have anything to do with it. Sentinel checks the firmware in the scanner and compares to what are on the Uniden file server.
/Ubbe
You should always have a spare SD card programmed identical to the one in the scanner, as a safe backup in your wallet or any other place that are always together with you or the scanner. They are only $10 so get one, 32GB or lower in size, whenever it is possible.What should I do.?
I will consider your suggestion. Thank you for your ideas.You should always have a spare SD card programmed identical to the one in the scanner, as a safe backup in your wallet or any other place that are always together with you or the scanner. They are only $10 so get one, 32GB or lower in size, whenever it is possible.
/Ubbe
