Will 396t work for clermont county ohio after rebanding..? And if so where can i find band plans
peteymcsweety Member Joined Feb 21, 2015 Messages 47 Location cincinnati. Ohio Jan 19, 2021 #1 Will 396t work for clermont county ohio after rebanding..? And if so where can i find band plans
hiegtx Mentor Premium Subscriber Joined May 8, 2004 Messages 11,186 Location Dallas, TX Jan 19, 2021 #2 peteymcsweety said: Will 396t work for clermont county ohio after rebanding..? And if so where can i find band plans Click to expand... If you mean the MARCS site for that county, you don't need to enter a band plan. For P25 systems, the scanner gets the band plan information needed from the control channel data stream. However, I see that the MARCS site in Clermont is Simulcast. That can be a problem for many scanners, including the 396T (or XT). See this Wiki page: Simulcast digital distortion - The RadioReference Wiki Here's a map of the tower locations for the Simulcast site: RR Database Home The most complete database of radio communications data www.radioreference.com
T tvengr Well Known Member Joined Feb 10, 2019 Messages 9,276 Location Baltimore County, MD Jan 29, 2021 #3 peteymcsweety said: Will 396t work for clermont county ohio after rebanding..? And if so where can i find band plans Click to expand... Do you have a 396T and if so, do you have programming software?
