- Joined
- Dec 13, 2020
- Messages
- 5
Yes, it was updated.
Thanks!
Thanks, I realized after I wrote the question that I could just as easily go look! Sorry!
Thanks!
I have a SDS-100, I entered the control channels donslade provided in Sentinel replacing existing freqs for Simulcast and I'm back up and running... Thanks for the help!
If you are only using the main database & location, no you cannot edit the main database.Do you have to make up a favorites channel to do it or can you edit the current database? I've searched and can't seem to find how to do it on the SDS100. I'm new to this unit. Not new to scanners. I'd appreciate any direction.
If you need to edit a system from the database, or create a new system (that is not in the database), then that needs to be done in a Favorites list.
Are you trying to monitor the El Paso system? Your location is listed as Flower Mound, here in the DFW area. Is there a DFW area system you are trying to add?
I'm TDY in El Paso.
Take a look at the system in the database:I have been having no luck lately with El Paso Sheriff dispatch? did they go encryption? what system or frequencies are they on?
