Server Outage 4/29/2021
j2brown
I'm also not listed as a provider (and thus not a premium subscriber). Possibly related?
ricbeck
Pocono PA
I'm down also. When I log into Broadcastify my subscription status in not premium either like it should be.
allenc85
I think but not sure if your feed is down longer than 6 hours they automatically remove you from premium. Should go back to premium when your feed comes back up.
bbtkd
Earth
What would be great is if they would modify the scripts that notifies you that your feed is down, where they would check to see if all of the feeds on the same server are down. Then send an email saying they are down, not me.
k2hz
Rochester, NY
Same here, feeds went down at 12:57am - still up on my LAN. Rebooted and feeds wont restart since can't connect with server.
StellarNova
Connections to Audio1 have been lost
My connection via Audio9 went down minutes prior but was restored and is currently still working
Intermittently I see a successful connection to Audio1 and then its lost again. I have not tested anything else.
nhitchan
Harmony PA
+1 same issue here. I run a custom linux service using a gstream pipe off of a raspberry pi (before they had official support!). I'm in a constant retry loop to connect to audio3. Another thing i noticed, the premium account you get for hosting a feed seems to have disappeared from my account. I can still go to my stream and manage it though.
gcurtis79
Davenport, IA
I think it happens almost immediately. My feed went offline around midnight central time, and when I realized it around 1:00am I was already off premium.
I wish they would put a 24 hour buffer on that. I've been a provider for over 10 years...
gcurtis79
Davenport, IA
Please see this thread in the Broadcastify Administration forum, which is where feed providers view and discuss issues: Feed Down, Problem on Server Side
Either this thread no longer exists, or is attached to a users feed provider status.
If you have to be a feed provider to access that, it will be unavailable. With my feeds currently down, I am not considered a provider at the moment.
kmckinney7
OK, not just me. My call broadcast is up but my IceCast just keeps trying to connect without success.
EW1407
Glad I searched the forums before pulling my hair out. My feed is also down. Unable to connect to audio3
Edit:
Mine is also back online
