I’m not using the search function on the scanner. It’s just a system that I built manually that I’m scanning through. Guessing it’s got a few hundred channels in it, between the various “departments” (bands in this case). I’ll happily upload the file when I get to the computer at some point.
In any case, both videos show the same exact system being scanned. In one video it takes almost a minute to get through the system, and in the other video it makes two passes in a few seconds if I recall correctly.
The inconsistent behavior makes me wonder if it is the cold solder joint issue.
I don't think that's it, it's alot of channels to go through, plus if you get any intermod/interference it will slow it down.
