I have been following this DMR system I found and logging with SDRTrunk. I don't understand a bunch of these messages in the log. Could someone help me in determining what each one means? I believe it is a Moto Cap+ single repeater, and I know many of the HT's they are using are Motorola based on their discussions. The CC being used is 12.
I'd love to understand what is going on behind the cloak.
Code:
20210615 093043,FAILED,[CRC ERROR] SLC TIER III CONTROL CHANNEL LARGE NET:0 SITE:32 SLOT COUNTER:0 MSG:280800000
Code:
20210615 093043,FAILED,[CRC ERROR] SLC UNKNOWN OPCODE:4 MSG:49108
Code:
20210615 092418,FAILED,[CRC-ERROR] CC:8 CSBK *UNKNOWN* VENDOR:114 UNKNOWN OPCODE:10 MSG:0A72DEA3FEAD12B1523C3980
Code:
20210615 091958,FAILED,[CRC ERROR] SLC HYTERA XPT ALL REPEATERS BUSY MSG:800000000
Code:
20210615 091648,PASSED,CC:10 MULTI-BLOCK CSBK CONTINUATION FINAL BLOCK:NO MSG:6A02D823FE2D0291562D3A80
Code:
20210615 091228,PASSED,CC:6 MULTI-BLOCK CSBK HEADER VENDOR:UNKNOWN (213) UNKNOWN CSBKO:57 MSG:B9D581CFA9131C21E0FBCC67
Code:
20210615 090812,FAILED,[CRC ERROR] SLC MOTOROLA CON+ CONTROL CHANNEL NETWORK:0 SITE:128
Code:
20210615 090350,PASSED,RATE 3/4 DATA CONFIRMED:CA409E0886BCB49EEC6D47FAB329BCA9 UNCONFIRMED:EA29CA409E0886BCB49EEC6D47FAB329BCA9
Code:
20210614 191237,PASSED,CC:12 FM:UID# TO:16448250 IP FROM:12.48.139.75 TO:13.250.250.250 UDP PORT FROM:4005 TO:4005 ARS DEVICE REGISTRATION-INITIAL DEVICE:UID#
20210614 191237,PASSED,CC:12 CSBK PREAMBLE FM:UID# TO:16448250 DATA BLOCKS TO FOLLOW:17 MSG:BD008011FAFAFA308B4B8B9D
Code:
20210614 191237,PASSED,SLC ACTIVITY UPDATE TS1 [95] INDIV DATA / TS2 [00] IDLE MSG:1A09500FE
Code:
"2021:06:14:19:12:37","","DMR","DATA_PACKET","UDI#"," (16448250)","","462.675000","TS:2,"CC:12 FM:UID# TO:16448250 IP FROM:12.48.139.75 TO:13.250.250.250 UDP PORT FROM:4005 TO:4005 ARS DEVICE REGISTRATION-INITIAL DEVICE:UID#"
"2021:06:14:19:03:12","","DMR","DATA_PACKET","UID#"," (16448250)","","462.675000","TS:1,"CC:12 FM:UID# TO:16448250 PACKET:733A04A16D1739BE139A08026A79B15B7AAA7E3886BC6219A86D47F425B3A1A3CE90333886BCB04DA87D5AFA9260E401"
