I am using a Whistler 1080 with the radio ID tags turned on and when I hear a car number dispatched I wait for the car to respond and then write down the radio ID for that car. I'm thinking there must be a better way?
The only other way is to set the TG to record and go back through the recordings and write it down like you are now. There is no auto-logging/identifying RIDs that I know of.
Im wanting to change the radio id to the car or truck number once its identified. It will be easier to follow calls. Im in Pitt County
Yes, that makes it easier to ID users/units, however in many areas the RID for units changes, ffor example EMS 1 today might be 12345 but tomorrow, when a new crew is in EMS 1 it becomes 54321. Most of the times (I've found, and especially for FD and EMS) handhelds are used and crews rotate. PD doesn't do this as much, but even there posts rotate and change in some departments, today's 1A12 is 3C14 tomorrow. It is a lot easier to ID FD, EMS, PD without specific unit numbers.
