Thanks for the info
Thanks for the info
Trucker700, what you are hearing that is not published on the RR data base are "Airline Company Freqs."...this is for pilots to call when they are about half an hour out from landing to call their respective airline and tell them about special needs pax., unaccompanied kids, and special requests. This info is confidential and not published. A lot of this info is now transmitted via ACARS.
On a separate note, I have an Icom airband receiver and it is "mind blowing" as to how sensitive it is, I pick up planes over Canada living in Ohio. You cannot compare Icom's, they are professional grade.
I have an Icom 5100A dual band transceiver. As for antenna, a Larsen dual band 5/8 wave.Which particular Icom airband receiver do you have, and what antenna are you using?
For mobile in my pickup, i use the Uniden 436. I found it works quite well. When I was driving over the road, I used my SDS100 and a Larsen scanner antenna mounted on the passenger side mirror.Trucker700 - I'm wondering if you made a selection for a new aviation radio? I recently purchased the Uniden BCT15X and find little difference between it and my SDS200 while monitoring air band frequencies. Oddly enough, I found a couple of instances where the SDS200 would pick up a distant signal while the BCT15X was silent (both radios were monitoring the same frequency). Please note I feed all of my scanners and SDRs from the same antenna (MP Antenna 08-ANT-0861) and use the Electroline Amplifier/Splitter. Despite what others say, my SDS200 is hardly deaf and performs quit well on the VHF bands.
That is something I have looked at. But, I didn't know how well it would work. I have a couple of the cheap dongles that didn't really impress me.I've been seeing excellent performance scanning/searching the air bands using a SDRplay RSPdx SDR receiver. It performs so much better than any scanner I've ever used, including the BCT125AT, BCT15X, and all the rest! I'm using a SIRIO SD 2000 N 100~2000MHz discone antenna. You'll start hearing what you've been missing, and seeing it as well.
I use the same antenna here from my Uniden 780 XLT and it works fab for me. I am 2o miles due north of O'Hare and the 780 can hear about everything from ORD. My 325P2, not much at all.Trucker700 - I'm wondering if you made a selection for a new aviation radio? I recently purchased the Uniden BCT15X and find little difference between it and my SDS200 while monitoring air band frequencies. Oddly enough, I found a couple of instances where the SDS200 would pick up a distant signal while the BCT15X was silent (both radios were monitoring the same frequency). Please note I feed all of my scanners and SDRs from the same antenna (MP Antenna 08-ANT-0861) and use the Electroline Amplifier/Splitter. Despite what others say, my SDS200 is hardly deaf and performs quit well on the VHF bands.
I might have to try an SDRplay.
Thanks for the tip.
James
AKA: Trucker
