Multiple channels under the same feed?
W1cjf-1
Brockton,ma
Am i able to stream more than one feed from the same account? I scan 2 channels and am dedicating a 2nd rig for channel to. It gets crazy so I want to separate the streams.
Deziel0495
PE/NB Database Guy
PEI
The second feed says " in transition" how long until i can use the second feed?
A live audio admin has to manually work your application, so please be patient.
Most times you will get an email within 24-48 hours stating whether your feed has been approved or denied. If there are any questions about your application, you will be contacted and asked to provide more info.
W1cjf-1
Brockton,ma
ok it says it is in transition i am just finalizing my PI to start broadcasting. Thanks
