What cable would I need to be able to send alpha tags via scanner cast from a bcd996p2?
kb0rpj Member Feed Provider Joined Oct 4, 2004 Messages 271 Location north central mo Apr 23, 2022 #1 What cable would I need to be able to send alpha tags via scanner cast from a bcd996p2?
doctordialtone Member Joined Apr 18, 2009 Messages 6,189 Location CT Apr 23, 2022 #2 kb0rpj said: What cable would I need to be able to send alpha tags via scanner cast from a bcd996p2? Click to expand... This one.
R rocky28965 Member Premium Subscriber Joined Nov 19, 2017 Messages 620 Location Otago, NZ May 2, 2022 #3 Is that a standard usb cable or does it have prolific chip ?
doctordialtone Member Joined Apr 18, 2009 Messages 6,189 Location CT May 3, 2022 #4 rocky28965 said: does it have prolific chip ? Click to expand... It doesn't have a chip.
kb0rpj Member Feed Provider Joined Oct 4, 2004 Messages 271 Location north central mo May 3, 2022 #5 Apparently I am missing something here. I ordered that cable but I do not see where it connects to the bcd996p2. I see a serial port but no USB port. Do I have to order a USB to serial adapter as well??
doctordialtone Member Joined Apr 18, 2009 Messages 6,189 Location CT May 3, 2022 #6 kb0rpj said: Apparently I am missing something here. Click to expand... One end plugs into the PC. The other end plugs into the scanner under the Silver Knob.
kb0rpj Member Feed Provider Joined Oct 4, 2004 Messages 271 Location north central mo May 3, 2022 #7 Aha! Sneaky little bugger!
