Of course you're missing transmissions. The radio has to scan between multiple control channels, pausing on each to look for grants, then moving on. The default dwell time per system is 2 seconds, which is really the lowest you want to set it at, otherwise you're going to miss even more activity. If it's that important that you don't miss transmissions, then you'll need more than one radio to monitor multiple systems.
