Sticky Thread For Mid-Atlantic MilAir 2022
pro106import
Milford, Ct. perched high above Long Island Sound
Guys
I'm hearing (what sounds to me) P-25 encrypted signal. I have this in my scanner as CGAS E. City NC Air Ops. There are a couple of CG aircraft down there but they are quite low, so not sure what I'm hearing is coming from. I don't have digital decode capability.
What's the freq?
Tech792
Central NJ
Ron.....269.0 is showing on the NY chart (dated 2022) as NY Class B air space and is paired with 128.125
I tried to upload the document but it says "upload too large for server to process".
Here is a link to the FAA document: https://aeronav.faa.gov/visual/03-24-2022/PDFs/New_York_TAC.pdf
(269.0 is referenced on the right side of the map under Long Island)
mdmonitor
Pete
Thanks. I was going to put it in my scanner but won't since it's low altitude use.
On Sunday, May 29, the President and the First Lady will travel to Uvalde, Texas, with arrival and departure at Joint Base San Antonio-Kelly Field, San Antonio, TX.
Preliminary reports has AF1 Arrival at 9:10 ET/10:10AM CT and departure: 5:30 ET/6:30PM CT.
I have that one in my rotation as discrete air to air Langley, has the user changed?
That 381.8 P25 may have been skip from say Dover AFB Trunked system which has several P-25 freqs right near 381.800
and am sure other Mil trunked systems in the area.
1715 local Tanker offloads to NOBLE-22,21 in the CAP.. Where you from? New Orleans is answer so still 159 FW Louisiana F-15 guys.
1745 RCH-432 C-17 inbound Dover first with CP 349.400 req Customs/Ag etc.
Not showing on ADSB at all since spotted off Lajes earlier as C-17 #93-0603 445AW.. Strange..
Also around 1730 DECOY-77 C-17 #94-0070 off Martin State going back home West Va.
