RFI-EMI-GUY
- Joined
- Dec 22, 2013
- Messages
- 6,868
Probably not.Maybe if they hold their radios up and to the side slightly, it'll improve the signal performance.
One other interesting thing that I forgot to mention before is that most of MBFR are actually using Motorola P25 APX series portables on the new Harris P25 trunked system whereas PD and most local government is all Harris equipment. From what I have seen the Motorola's are working flawlessly. I believe they were purchased via the Broward contract pricing. In fact, I think the Motorola's are better than the Harris in terms of usability.
They both have vendor specific featuresI've seen it expressed as: Harris uses the basic P25 protocol, while Motorola of course chose to "embrace and extend" the specification for their own equipment as a value-added carrot. So they will all talk to each other, but without some fanciness.
MBFR Dispatch (TG1102) is now running encrypted since June 1st.A few updates:
MBFR Dispatch (TG1102) is now running encrypted since June 1st. I do not believe this was originally planned and I asked around and couldn't get a good answer as to why but the only response was that they are working to resolve "reception" problems with the system (apparently by enabling encryption on the FR Dispatch Channel 1?!?) Basically we are now only left with the Pulse Point app for the keeping up with the fire rescue calls.
MBPD continues to have radio problems on the new system. They were really bad during the past memorial day weekend. PD unit transmissions are heard with garbled or unintelligible audio. They think they have narrowed the problem down to timing synchronization caused by auto roaming to the Miami P25 system but there is no fix. The work around is that encryption is often turned off for TG1002 and/or TG1003 (MBPD Ch1 and Ch2) during shift changes when the PD units are generally on the causeways outside the city.
The operations protocol for turning encryption on and off is this: PD dispatchers can unencrypt their transmissions for their own individual consoles (ie for BOLOs, ect) and the on duty supervisors in the communications center now have system access to disable all encryption on a particular talk group channel (including portables and mobiles) which has to be approved by the top big brass.
WTF! I would have been told about this at Miami-Dade Fire. I am the C Shift "Countywide" Hazmat OIC and I would have been in the loop on this considering we go into MB for Hazmat calls on a regular basis. MB does NOT operate a dedicated Hazmat Unit, MDFR and MFD handle their hazmat calls. I can talk to MB from my APX7700 because I have their new system, and old, programmed but NOT encrypted. We shall see I guess.....
Thanks, I will just ask for the MBFR units on scene to go to an interoperability Tac Channel (That isn't "E") when I respond.The Main Fire Rescue dispatch channel TG1102 is definitely now on full time encryption. The Fire Talk and Tac channels are still in the clear at least...so presumably Hazmat situations would be handled on a Tac or Talk channel. I will say I am impressed how quick the people in the communications center are at switching on/off encryption as well as patching on the new system. They are doing it multiple times a day for PD especially on the main dispatch channels for BOLOs and shift change and on the 'Tac 7' channel (TG1008) when then need to talk to the county PD/Aviation.
I have a Motorola APX question for everyone. Does Motorola charge a license fee for enabling encryption on a per radio basis? Now that Fire Rescue needs encryption feature on for all of their APX portables and mobiles it seems that would have come at a hefty price.
If the radio wasn't ordered with the same type of encryption as in use (ADP, AES, DES, etc) then yes, they will have to be upgraded with the appropriate flashes purchased thru MSI. Other options like mult-key (more than 1 enc key) may also raise the price. APX radios all came with at least single key ADP software encryption, but around 1st Q 2018, the customer was required to specify an algorithm and got either single key AES-256 or ADP (upon request). If NO ALGO was specified, the radio has to go to the depot to get the MACE flashed.I have a Motorola APX question for everyone. Does Motorola charge a license fee for enabling encryption on a per radio basis? Now that Fire Rescue needs encryption feature on for all of their APX portables and mobiles it seems that would have come at a hefty price.
Anyone know why the encrypted the Fd dispatch
I have been to a few fun roof top events there, But i usually avoid ocean drive.Yeah all PD and Fire Dispatch is fully encrypted all the time. I'll miss listenting to PD respond to 1020 Ocean five times a day to break up fights.
