adsbgreenock
Hi there guys,
i have a small issue that something got corrupted in darkice.cfg or darkice.1.service on systemd.
When i run bcfy shell and try to "enable feed now"
i get this error and no audio :
Which darkice instance do you want to configure?
Instance Description
[1] Darkice Instance #1
[2] Darkice Instance #2
[3] Darkice Instance #3
[4] Darkice Instance #4
Enter Instance ID # to configure [1] or [q]uit: 1
>>>>>> Configuring Instance #1
Sources Available:
Card ID Card Description
[1] PulseAudio Loopback 1
[2] PulseAudio Loopback 2
[3] Device [USB Audio Device]
Enter Soundcard Card ID to use for this broadcast: [3] or [q]uit: 3
>>>>>>>> Configuring Card ID 3
Enter Broadcastify Username: adsbgreenock
Enter Broadcastify Password:
Retrieving Feeds for adsbgreenock...done.
Your Broadcastify Audio Feeds:
Feed ID Feed Description
[36339] Clyde Estuary Radio
[36537] Firth of Clyde Marine (Lower Area Antenna 2)
Enter feed ID to Configure for Darkice [36339] or [q]uit: 36537
>>>>>>>> Configuring: Firth of Clyde Marine (Lower Area Antenna 2)
Configuration Written.
Do you want to connfigure this darkice instance to start on boot? [Y/n]: y
>>> Enabling darkice_1 to start on boot
Done. Press [Enter] to continue...
Configuration Finished!
Do you want to start this darkice broadcast now? [N/y]: y
Starting darkice_1...
● darkice_1.service - Darkice Instance 1 Service
Loaded: loaded (/etc/systemd/system/darkice_1.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2021-12-05 00:49:59 GMT; 12h ago
Main PID: 1144 (sh)
Tasks: 3 (limit: 2059)
CGroup: /system.slice/darkice_1.service
├─1144 /usr/bin/sh -c /usr/local/bin/darkice -v5 -c /home/pi/bcfy/configs/darkice/darkice_1.cfg > /home/pi/bcfy/logs/darkice_1.log 2>&1
└─1147 /usr/local/bin/darkice -v5 -c /home/pi/bcfy/configs/darkice/darkice_1.cfg
Dec 05 00:49:49 bcfy-7a4e0cec systemd[1]: Starting Darkice Instance 1 Service...
Dec 05 00:49:59 bcfy-7a4e0cec systemd[1]: Started Darkice Instance 1 Service.
Dec 05 00:51:19 bcfy-7a4e0cec systemd[1]: darkice_1.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Press [Enter] to return to the main menu...
This of course leads to the feed not starting there and then, however on boot it starts and im puzzled.
I may need to replace darkice.1.service file or darkice.cfg to start again if anyone could post the contents of the files.
Any help greatly appreciated.
Many thanks
Regards
Sources Available:
Main PID: 1144 (sh)
Many thanks
Regards
