this is from RRDB below. I created a new system MOT2 Quincy PD and GRP Quincy PD P25 w tgid 1 but there are no columns to enter the NAC numbers ? can anyone suggest a way to have my local PD on my BCD996p2 ??? see attached
The frequencies that are listed are not part of a trunked system. Program them in a conventional channels system. Set the audio to digital, which will then give you a field to enter the NAC code.this is from RRDB below. I created a new system MOT2 Quincy PD and GRP Quincy PD P25 w tgid 1 but there are no columns to enter the NAC numbers ? can anyone suggest a way to have my local PD on my BCD996p2 ??? see attached
These are conventional channels so you can enter them as such rather than trunked. You can disregard the NAC Codes if you want, if they are incorrect they can block your scanner from hearing them, just like an incorrect PL Code.
Otherwise you can enter it as a P25 Single channel trunked system (Not Motorola) and set it to ID Search. This will allow you to see TG numbers (used often in P25 conventional systems) as well as Unit ID's (if that feature is turned on).
It's a BCD996P2!You didn't mention what type of scanner
It's a BCD996P2!
I would suggest following this programming recommendation. If the department happens to be using more than 1 talkgroup (channel) or more than 1 Slot, you won't understand why you're hearing different conversations.
They aren't. If he does what you recommend he has to create a separate system for each frequency.
You don't have to create separate systems for One Channel P25 Systems. You can add the frequencies to the Site tab and it will scan as if it's conventional. Put it in ID Search and see what comes up. Besides talkgroups/slots, radio ID's can be ID'd and text tagged as you go along. I have this set up on a few systems I regularly monitor.
That is still overly cumbersome and unless he really wants to see how the IDs unnecessary. While it's sitting on one rarely used site, he'll risk missing traffic on another.
More than 1 slot?I would suggest following this programming recommendation. If the department happens to be using more than 1 talkgroup (channel) or more than 1 Slot, you won't understand why you're hearing different conversations.
More than 1 slot?
P25 conventional uses talk groups and not slots. P25 Trunking Phase 2 will use slot 1 or 2 (0 or 1) and DMR Trunking uses slot 1 or 2.
Lots of bad advice in this thread. The reason, as explained by UPMan for the OFT option for conventional P25 (yes, a misnomer) channels is because that's the only way the software developers could get UID to display.
With that said, I hope the OP ignores the noise floor and programs his scanner so it works.
I hope the OP tries different methods to get the best programming that works for him. I think the "noise floor" has some experience, and could explore his suggested option if that's what he chooses to do. Remember, it's just a suggestion on how to get the most out of a scanner. On that note, enjoy your 996P2!
Quincy Police is Conventional
Three channels
Not a System - The OP only needs to change his existing Conventional 3 QPD from PL Tone/Analog to P25/Digital and if he feels it is needed, select the NAC otherwise Auto for the NAC will work.
