what exactly were ur issues? what type of system are u guys on. we’ve been using G5s as our only pagers for 3 years and haven’t had a single issue with QC over our dispatch TG or any issues monitoring our ops TG
Currently mixed mode in region. Quick call hasn't been issue so far since update prior it worked fine.
Analog and mdc or csq. Before about 20 percent failure rate in decode was noted in scan on mdc. After update at least 80 percent failure to decode rate using mdc. What is odd is it only does it certain knobs or zones and all have same settings. Almost frequency picky. Scanning good luck with vhf with mdc enabled. Now csq seems to emit this issue without mdc enabled with pl pr dpl using csq setting.
It also seems to at times stop on a scan in mdc as if it knows activity exists but only a quiet hiss can be heard as if it is failing to decode mdc. This seems to only occur so far on mdc on certain channels and yes same settings were put on all channels.
700 seems fine on p25. But as mission critical it cannot be relied on and this is issue huge issue. Would be like having a apx8000 or a viking8000 and it only un muting on 700 or when it decides on vhf.
To a scanner user they can say it isn't a big deal. However mission critical someone gets hurt relying on this it becomes a huge issue in legal forms.
Vhf only was attempted on g5 yielding with same results without any 700 data.
