@Whistler_Support I found a bug in firmware 7.4. The Flexstep function is not working. I tried to program a conv freq 143.1600 but it is stored as 143.59375.
This doesn't happen in firmware 7.1.
It's just an indicator of when the DSP are decoding a digital signal or an analog signal. It actually only unmutes if the digital signal have voice information. So it's not a control but a visual indicator of a state in the scanner.I am wondering about, HOW the h.... do i turn off MUTE in SCANNER CONTROLL for TRX-1 / TRX-2?
Please inform me what country you have selected.@Whistler_Support I found a bug in firmware 7.4. The Flexstep function is not working. I tried to program a conv freq 143.1600 but it is stored as 143.59375.
I use UK.Please inform me what country you have selected.
After updating to version 7.4, did you perform a Reset to factory Values to remap the EEPROM?
It's because in DMR and NXDN it is searching the voice channels and not using the control channel and needs all of them to be entered in the site list.Question about software partitioning Trunked Radio System.
Tell me why in the Site list in the site No. works searches among frequencies the Site No. for dmr, nxdn, but for Project25 he sees only one carrier information frequency.
If you enter two or more frequencies in the Site No. list of frequencies, it works only with the first frequency in the Site No. list.
Press MenuI use UK.
No, I haven't reset factory. How to reset?
I will report the results.
Still not working.Press Menu
Go to Program Menu and press SEL
Press SEL again when on Global Settings
Go to Default Vals, press SEL, Menu, SEL
Go to Bandplan and select UK
When you have flexstep enabled, the steps of 6.125, 10, 12.5, 20, 25, and 50 will be cut in half.
Step sizes of 2.5, 5, 7.5, and 8.33 will remain unchanged
Whoever informed Whistler about the UK bandplan stated 6,25KHz steps for 138.000 to 219MHz. Your 143.31875 frequency are 1.25Khz too low but even with flexstep it will do 3.125KHz steps and can't hit exactly at 143.320MHz.In previous fw, i able to save 143.320.
I lived in Indonesia but use UK bandplan, because that's the nearest one.Whoever informed Whistler about the UK bandplan stated 6,25KHz steps for 138.000 to 219MHz. Your 143.31875 frequency are 1.25Khz too low but even with flexstep it will do 3.125KHz steps and can't hit exactly at 143.320MHz.
Are you sure you want to monitor 143.320MHz as it seems to be an illegal frequency in UK? Have you checked the databases of OFCOM and WTR if the frequency are valid to be used?
My Whistler scanner are actually 1KHz off in frequency, and my Uniden 1Khz off in the other direction. Scanners aren't that accurate in its frequency tuning. But it is annoying if the frequency on the display isn't showing what you want.
I stated lots of band segments to Whistler for the Sweden bandplan so if you are sure that for example 143.000 to 143.990 always use 20KHz steps then ask Whistler to add that segment to the UK bandplan. Using flexstep will then allow 10KHz steps to be used.
/Ubbe
Ask whistler_support for the document that you fill in with the bandplan you want. They seem very helpful to add new country configurations.I lived in Indonesia but use UK bandplan, because that's the nearest one.
All earlier versions of Flexstep (USA and E versions) prior to 7.4 allowed for FlexStep data entry in steps of 1.25kHz however the unit was tuning to the closest step from the bandplan to the frequency that was entered. Your version 7.1 data entry of 143.32 was in text only as the radio was tuning to the closest step from the bandplan being 143.31875I lived in Indonesia but use UK bandplan, because that's the nearest one.
And yes, in firmware 7.1, you can add a conv frequency 143.320, exactly as you type.
Please see my video below
There can not be two slashes after each other in a Windows file system, \\TRX-1e.iniWhy does this error appear when I close the program?
Found bugs:
U/VHF AM predefined service search is set to NFM by default. At least in Netherlands band plan. This can only be changed to AM in the scanner menu (not in the software). This needs to be repeated every time you write data to the scanner. Also, a better name would be VHF/UHF AIR (or VHF/UHF AIRBAND).
Motorola BP (Basic Privacy) encryption is not muted while encrypted audio is set to silent. Tested while receiving encrypted users on a plain Motorola repeater. No fancy capacity plus or connect plus. I need to mention it used RAS.
Feature request:
Add option to reset skipped frequencies/channels on power cycle.
Yes, that was how it was explained to me but both analog and digital are now monitored from both A and D channels, so there's no way to only search digital or only analog.The channel number followed by A was intended for Analog only (ignore digital)
The channel number followed by D was intended for Digital only (ignore analog)
