I've been doing some research on how/what makes lojack tick and a concept came to mind. I hope some of you can come in an chime with your thoughts.
Lojack operates on 173.075 Mhz which is a dedicated vehicle recovery frequency. (non exclusive) which means you too can also lincense and operate on this freq for the stated purpose.
Lojack uses gear manufactured by Motorola and an encoding format called "Continuous Phase Frequency Shift Key" (CPFSK) which from what I understand it is a very common format for data modems.
The gear could be manufactured by Joe Blow communications however Lojack uses Motorola AIEG (automotive industrical electronics group) to have their units manufactured.
Now if you were properly licensed, you could conceivably install a CPFSK modem/radio in your car and in case of theft send an activation signal for the modem to enter "beacon" mode while transmitting your vehicle's TAG number which would come up stolen on police computers.
Police cars equiped with receivers listening for CPFSK on 173.075 Mhz would pick up your signal and instead of receiving the lojack CODE the cops would receive your car's tag number, which on search would come back as a hot car.
They could follow the signal jus the same as they would follow the lojack signal.
Now lojack would probably require the modem to transmit a preamble to exclude non lojack units but that is where the courts should probably enter the fray and madate that a public entity should not enter into a monopoly structure with a private co.
Your thoughts ???
Your thoughts ???
