- Joined
- Jan 19, 2007
- Messages
- 85
Hey I was wondering if a standard 3/4 inch hole saw will work for my nmo mount, or will the diameter of the bit make the hole to big. Any suggestions will be apreciated.
When I installed my NMO dual band my truck antenna on my truck, I used a standard 3/4 hole saw. Been over a year havent had a single problem with it.
I used blue masking tape to avoid scratches and drilled a pilot hole prior to deploying the step drill ...de-burring and final hole sizing was acomplished with the Dremel
Dont use a 3/4 hole saw.. Its too large. The mount will not fit securely. I dont use a step drill bit I use the antenna hole saw . If you have to use a step bit drill only til the mount fits securely and install the cable from the hole into the car not from the mount up through the hole.
