Hyundai Santa Fe
TPRI24
09 Santa Fe install
I recently installed a PSR-600 with a Larson Tri Band nmo mount.
I was going to mount it into the center console but did not want to lose that space.
I wanted a descreet install so I mounted the scanner verticaly in the door map pocket.
This required the removal of the door trim and running the coax to the door.
The antenna is mounted on the roof. The biggest problem was running the coax and keepimg it away from all the airbags!
The only problem with this setup is that I cannot read the display while driving!
I know where the scan, pause,L/out, and fav buttons are located and can hit them as needed.
This setup works fine for me.
