Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
  #21 (permalink)
Old 04-04-2012, 7:09 PM
Do all the troy kits have the gap where it meet the glove box?
I'd jump on one if it aligned properly..
  #22 (permalink)
Old 04-04-2012, 9:59 PM
eagle15's Avatar
I don't think they all have that problem I was in a hurry when I installed mine and need to redo it and make it look right.
I am here: http://tapatalk.com/map.php?dtscsw
  #23 (permalink)
Old 04-04-2012, 10:05 PM
All the pictures I have seen show that gap. I would really like to see some without.
What was the approx price on that unit?
  #24 (permalink)
Old 04-05-2012, 10:49 AM
eagle15's Avatar
If I remember correctly I paid $350.00 for it.
I am here: http://tapatalk.com/map.php?zdptvb
  #25 (permalink)
Old 05-05-2012, 7:12 PM
I see the 4x4 shifter in there. I saw on their website that it was not compatible with the shifter. Was there a trick to get it installed. Just picked up a new sierra 3500hd crew cab with 40/20/40 seats.
Also you sure thats a troy. I cant find it on their website but I found it on jotto desk
Frank
  #26 (permalink)
Old 05-05-2012, 7:52 PM
W6XPA's Avatar
Smile Rub the coax?
Originally Posted by cbrrider06 View Post
Also I am a firm believer in NMO mounts if any one has done one where did you drill and how did you rub the coax????
Don't rub the coax the wrong way!
  #27 (permalink)
Old 05-05-2012, 11:49 PM
I rubbed it the wrong way and the SWR was all out of wack.
  #28 (permalink)
Old 05-05-2012, 11:52 PM
W6XPA's Avatar
Ikaw if there are any bends in the coax that have causes a crease then you screwed. New coax time.
  #29 (permalink)
Old 05-05-2012, 11:57 PM
W6XPA's Avatar
also, were you soldering all of your own connections?
  #30 (permalink)
Old 08-13-2012, 11:26 PM
Just to follow up. Apprently when I searched before I could not locate anything about this console on troy website and assumed it was a jotto product. Well I ordered a jotto product and now stuck as it will not work in a vehicle with the shifter.
Frank
  #31 (permalink)
Old 08-14-2012, 6:02 PM
cg cg is offline
The problem I have with that console is that you can't see the lowest radio (at least I couldn't). And the horizontal consoles allow too much glare off the faces.
I have a 2011 Chevy Silverado. I need a console that will allow an angled face. I had made my own but I would prefer a commercial mount. I am installing (3) 996XTs and a commercial dual band radio.
Also if you are going to do much work on the Chevys, you should look at the upfitter manuals online. There is full wiring harness info available on them.
chris
  #32 (permalink)
Old 08-14-2012, 6:27 PM
BoxAlarm187's Avatar
Are remote heads an option? This is my 2008 Silverado, using two remote-head radios and one remote-head scanner mounted on my full-length console (factory subwoofer located within the forward portion of the console).
When the man at the door announced, "Alcohol, Tabacco, Firearms," I naturally assumed he was making a delivery.
  #33 (permalink)
Old 06-01-2018, 1:02 PM
Originally Posted by eagle15 View Post
Mfg Troy consoles took all of about 15 min to install. In my 2008 Chevy silverado work truck. for antennas I install them on my headache rack
I am here: http://maps.google.com/maps?ll=35.473594,-97.396988
I know this thread is from 2012, but Eagle15, did you ever get that gap to go away on the right hand side of that console?? Just got myself a 2007 and like that idea, but have seen that "it wont fit" with the floor mount 4x4, if you got the gap to go away, im gonna take the plunge and buy that console too. Thanks!
