2012 Dodge Ram Ing noise issues
Mtnrider
Greene County New Yawk
Having issues with Ignition noise on my VHF Hi band radio. Have put a filter on the positive and negative wires and its still there. I have a 3db gain left fender mount and radio hooked to battery. VHF lo band has no such issue and as well hooked to battery. Tried moving antenna that didnt work.....Any ideas out there...Radio is a motorola PM 400,i have same set up in a 2100 dodge 1/2 ton antenna mounted on roof and no issues that radio is a CM 300.
HDMechanic
Calgary Alberta
Nothing you can due but live with the noise. I have been told the noise is caused by the fuel injection system and I havent heard of a fix. I know a couple of pepole with this problem in their Dodge pickups.
_Wilson_
columbia Tn.
i had a 97 dodge cummins that would cause noise on low band, never did find an answer, and it didn't matter if the radio was mounted in it or a another vihicle parked too close, when it was running, and a radio was within 50ft the radio would lockup .
ozzie
mn.
Mtnrider, private message me your phone number and I will call you regarding the problem.
_Wilson_
columbia Tn.
This is a Gas powered and my 2011 dont have the issue.....odd
yeah i don't think dodge puts cummins in half tons, another thing, i forgot, is the interference my radio was getting sounded more like a fire tone out, noting like static or alternator noise. really odd.
hope you can get it figured out
ofd8001
Louisville, KY
Would it be an insurmountable task to swap your two radios around just to rule out an issue with the PM 400 radio?
dixie729
Daviess Co., KY
Check your alternator on your vehicle. I had a noise that came from mine that sounded like what your describing. Changed my alternator and it fixed the problem.
Sent from my HTC One X+ using Tapatalk 2
Mtnrider
Its not he radio i had a relm in there till the other day and it did the same thing. As far as the alternator. the truck has 5500 miles on it and has done it since day one.....hope its not that...
ozzie
mn.
I have had this issue since I bought my 2012 ram also. Been to the dealer numerous times. Installed capacitors, more grounding , bonding and can't get rid of it.
_Wilson_
columbia Tn.
does your truck have one of those backup camera warning systems with the monitor made into the rear view ? i have heard some vihicles with that type warning system can/has caused radio interfernce. just another 2 cents worth.
ScanWI
MN & WI DB Admin
Wisconsin
If it's not the alternator, make sure you don't have any other type of power conversion device, i.e. Power Inverter. This will dump a lot of dirt RF into a radio, especially on 2m.
