I installed a 996XT and a DR-638 in my 2012 Honda CR-V this week and have one little issue. I cannot seem to find a good place to tap 12VDC power so that the radios work in the Accessory and Run Ignition positions.
On the interior fusebox under the dash I can find fuses powered when the ignition is in the Run position or on all the time but none that come on in the Accessory position.
For now I connected to a fuse that turns on in the Run position so it works while i am driving but this also means the radios cannot be used if I just have it in Accessory mode.
I also cannot seem to find a good place to tap off of from the cigar lighter sockets, the wires are all well hidden in harnesses.
Any ideas other than plugging into a cigar lighter socket?
