Does anyone use LED lights to illuminate your installs?
Stimpy911
I have been trying to find examples of installs that use any form of LED lighting to give some illumination to your radio consoles.
A kind of a subdued light, almost like your dash lights'
I am not looking for a roof mount that lights up the whole cab but something that remains on or can be turned on that sits on or near the console to give it just enough light to see.
Does this make sense?
If anyone has done anything to help light up your consoles can you post an example.
Thanks,
Steve
PACNWDude
I have seen that more in the stereo, mp3 car community. Often a nice mobile computer control head or stereo unit is lit with LED strips for ambiance or to set off the install. Mostly strip LED's from what I have sen though.
Often a different crowd with scanners and amateur radio, if lit up at all, it is with an ex cop car light or small incandescent task light on a flexible arm. Think Jotto console and black headed lamp goose necked over the radio.
Personally I have yet to add any lights to anything I have done though. Most have back lit buttons or the dome light is used when changing channels if more light is needed.
SCPD
QRT
Virginia
I don't know if it helps, but years ago I strung about 4 or 5 little Christmas lights in series and used them in the car, I don't remember why. Seems the ones I was using would take about 3V to light up. Maybe you got a wad of lights not worth untangling that you could cut up.
avgas
Alberta
I'm not sure if you have an overhead console in your vehicle but my 2014 GMC Sierra has a single soft white led that shines down onto the center console from the overhead console. This led is not visible when sitting in the truck because it is countersunk into the hole. You really only notice the area is lit up but you cant tell where the light comes from. Maybe this is something that you could try.
KG7SPS
Star Valley, AZ
I've had good luck with some bullet accent blue LED lights. The ones I got at AutoZone had lights attached to 12 vdc plug. Cut off the plug (keep track which lead is positive, the tip on the plug), connect to a 12 vdc source or into a line control by the dimmer switch. I even install one under the center console arm rest with a mercury switch so it comes on when the arm rest is lifted.
SCPD
QRT
Virginia
Bass Pro Shop has led light strips in their catalog. Used for trailers. Waterproof. Cut to fit.
