2012 VW Jetta GLI Install
bgav
Central MA
New to me CPO '12 VW MKVI GLI Autobahn DSG. My previous VW was a leased '10 MKVI GTI 6sp 2dr.
Requirements:
  • Grab & Go for PSR-800 (handheld/portable use, theft deterrence)
  • Covert/Low Profile
  • Semi-permanent
  • No holes
  • Excellent reception
  • Airbag friendly
  • Passenger friendly ;)
  • Easily operated
  • Clean install without a rat's nest of wires & cables
Like previous installs, I used Proclip mounts which are very secure, semi-permanent, require no modifications or drilling, and leave no trace once they're removed.
2011-2016 VW Jetta Console Mount
Large Button and Belt Clip Holder
Antenna is a Larsen Tri-Band mounted on a Larsen NMO trunk-lid mount, 17' of cable with BNC male connector installed (bought from The Antenna Farm). It's pretty unobtrusive due to the color of the car, it blends right in. Cable is zip-tied to inside of trunk using self-adhesive zip-tie clips and run under the interior trim and carpet to the center console. I'll throw a NMO weather cap on there when not in use for an even more covert appearance.
More pics to follow of Otterbox travel case, additional interior and exterior shots.
bgav
Central MA
Nice clean install. Looks good nice work. well done
Thanks. Clean & simple was my goal.
Rugged case for transport & storage of PSR-800 and accessories.
  • Otterbox
  • PSR-800
  • Microfiber Lined Soft Case
  • Spare batteries in holder
  • Belt Clip
  • Stock Antenna
  • Stubby Antenna (Nearfield/Spectrum Sweeper)
  • Earbud & 1/8" patch cord
