2008 Ford Expedition power
avdrummerboy
Mohave County, AZ
Had a question about getting main radio and accessory power through the firewall of a 2008 Ford Expedition. Does anyone know if there is a easy spot to run through (the battery is on the right side as sitting in the drivers seat.) I don't mind drilling a new hole and running it myself, but if anyone has done a similar install and knows a good spot to run it it would be helpful.
FFPM571
Nashvillle
There is no good place to get a firewall hole on the passenger side due to the HVAC system. We always would get a hole on the driver side and run power across the top of the firewall and into the interior. As long as your fused at the battery and well protected and tied to the existing harness you will have no problem my shop did and still does numerous expeditons and F series trucks
avdrummerboy
Mohave County, AZ
Thanks for the advice everyone, got it done, it's an old service car and there was a hole in the rubber boot upper left side of the firewall where it looks like the original installers ran power through originally.
