Trailblazer wiring help
redneckcellphone
southern comifornia
Ok so i ran the wire from the inside of the vehicle to the engine area for my cb radio. wired the ground and was going to wire the power directly to the battery. Due to gm's brilliant design for the batteries it wont work. Where could i easily hook the power up?
R
retiredmich
Guest
You can also hook it up to your fuse box with the radio so that when you turn on /off the ignition it will go on / off your CB.
ab5r
Be sure that the ground wire is actually a ground. Some places on a vehicle are no grounded.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Could also pull power off the distribution box under the back seat. I forgot how I actually pulled power off my battery now that I think about it.
N8OHU
I plan to use this once I get to the point where I can start installing stuff in my 2004 Trailblazer; I will have to build a distribution system to go with it, though.
Project25_MASTR
Texas
May my 04 rest in pieces…actually I haven't decided what I'm gonna do with it yet. It's sitting in a barn out at a friends. Was helping with the local Ironman race, went up a hill and noticed it had no power. Got to the top let the window down heard a noise that sounded a lot like the rods trying to play catch with the crank and turned it off. Looks like the front bearing is gone.
So I bought a 2013 Sierra…that I'm happy has plenty of radio space in.
