Rack Mount Cabinet
Colton25
Can anyone recommend a desktop rack mount cabinet that is more shallow in depth then the standard 18". I'm looking for a cabinet that is at most 12" deep and 8-10U tall.
03msc
RF is RF
The Natural State
Have you web searched for "shallow 8u rack" or "shallow 10u rack"??
Colton25
Yes I have, several different ways. I do my best to figure things out myself before I go asking
03msc
RF is RF
The Natural State
Colton25
I was looking for something like this, just more shallow.
Colton25
Those are cool, I already have one like above however it is the full 18" and it's way too big. I'm wondering how the particle board or whatever it is would tolerate me cutting what I don't need off the back.
03msc
RF is RF
The Natural State
If it's the MDF stuff I've been told it's pretty easy to work with. Might have to be careful with if it has the smooth black veneer stuff on it but probably could cut it, if you could disassemble it then probably much easier.
majoco
Stirrer
New Zealand
At the moment I'm using an old speaker cabinet that just happened to fit. I screwed some 1inch square batten to take the shelves and carefully measured everything for best fit. However as you see there are now a proper couple of items that are real 19" rack sizes so I'm going to have a rethink. If I plan everything I will end up with a system made from 9 ply sides, top and bottom with MDF shelving that I can re-arrange as necessary, power supplies and power switching will sit round the back and antennas will be connected with a patch panel. Maybe next week/month/year..... :)
http://forums.radioreference.com/at...nstallation-complete-jamesdale-desk-1-sml.jpg
enine
Bud Industries and Hammond both make various sizes and depths and you can order from places like digikey and mouser.
You can also buy just the rails and build your own box to mount them in.
PACNWDude
I bought, on an auction site, some used Zetron dispatch console racks. Some of these are shallow, 8-10" deep and 19" wide. They were made for 4217B audio panels and ALI displays and speakers.
May have some luck searching for Zetron gear and just using the desktop rack portion.
bharvey2
I've built a couple of rack mount enclosures. Usually I'll build the cabinet our of plywood and if I just have one or two devices to mount I'll drill and tap some aluminum angle and mount it in the cabinet. If there are many item to mount, I'll use some of the drilled and tapped channel that is used for making the two-post Telco racks.
ShawnInPaso
I also needed a custom size rack cabinet and just built my own. If for no other reason, you can save a bunch of money. Just some pine boards, a little glue and screws and a few rack rails.
These are old pics, but you get the idea.
N4GIX
Hot Springs, AR
Wow Bill, I really like that look. Now you have me thinking............:)
Since you are obviously handy with tools, perhaps the side profile with dimensions may be useful. The major feature is that the bottom is inset, which will allow me to still use my mouse, and the flat top will allow me to put my smaller 4:3 side monitor on top.
Once I manage to measure all of my gear accurately, I plan to use the "Front Panel Designer" software to create the templates for the 2u front panels and place my order for them:
ShawnInPaso
Thank you Bill, I may very well use that design. I'm in the process of redesigning the shack, not too sure what the end result will look like just yet, but most gear will remain in 19" racks.
