Josh380
Just got some lmr400 coax for my uhf setup, and my swr has gotten considerably worse. I'm thinking it's gotten worse because more of my signal is making it to the antenna, considering I was using a mix of rg8x and rg58a/u, with a coupler in between. All connected to a mobile 5/8 wave antenna with a ground plane kit, mounted on a painted aluminum push up pole. My coax is about 23ft long.
My question is, could the current routing of my coax have an affect on my swr (picture below)? I'm pretty sure I need a new antenna, at this point it's a toss up between the comet ca-f72gf, or the browning 6143. I'm not sure if the browning requires a ground plane....thoughts?
