Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 04-07-2016, 6:24 PM
Default Interfacing Zetron 4010 and Motorola CDM Radio - Pinout needed
Can someone please supply a wiring guide or pinout to connect a Zetron 4010 console to a Motorola CDM series mobile radio's accessory connector.
Zetron refuses to be of any assistance.
Thanks,
J. Birnbaum
NMFD
jbirnbaum@newmilfordfire.org
Old 04-07-2016, 7:22 PM
That Zetron 4010 uses 66 block punchdown to connect to the radios. The CDM accessory connector pinout is ususally posted on Batlabs website, just search for "Motorola CDM accessory connector pinout".
The 4010 console should have three black RJ-21 Amphenol connectors on the back. The console to 66 block connection is via the cable with the RJ-21 connectors. Then the Acceesory connector of the CDM radio gets punched down to the 66 block. The 4010 manual should have those 66 block pinouts.
Bet Zetron wanted $160 and hour for someone to muddle their way through that.
Old 04-07-2016, 10:32 PM
Default 66 block pinout.
Here is the pinout from the manual for the 4010. The manual itself is too large of a file to send from my email though. So here are two page pictures. Hope this helps.
Old 04-07-2016, 10:58 PM
You will probably want to use the RX filtered audio from the CDM accessory connector to feed the Zetron console. It doesn't change level with the volume control. You will need the ground to go with it.
Jim
Old 04-07-2016, 11:56 PM
cmdrwill's Avatar
Yup, that IS correct.
Old 04-09-2016, 3:06 PM
Talking Channel Steering
Last question, how do I go about channel steering the CDM-1250/CDM-1550's from the accessory connector using the Zetron 4010?
Old 08-11-2016, 4:33 PM
NMFD204 -
Did you ever get an answer about channel steering your CDM1250?
Chuk
Old 08-11-2016, 5:55 PM
SteveC0625's Avatar
There are a number of previous threads here on RR that contain plenty of info to set up channel steering on your CDM.
The older Motorola radios like the GM300 and MaxTracs also do channel steering in a near identical fashion. Search here and on repeater-builder.com and on the batboard and you will find more than enough info on channel steering. There may also be some documentation on batlabs.com.
Rochester-Monroe County 911 7010 1976 to 2003
Northampton Ambulance - Car 2829
KD2IAT --- WQPG808
Old 04-03-2018, 1:31 PM
Hey everyone, not to bump an old thread but I figured its better to keep the info in one thread. I just wanted to verify the pins used since I haven't used a 1250 for audio in before. The only pin I believe I'm stuck on is the TX - . Here is what I have mapped out so far.
Connector 4 TX + / Pin 2 Ext Mic audio
Connector 29 TX - / Pin ?
Connector 30 RX - / Pin 11 Flat/Filtered RX audio
Connector 5 RX + / Pin 7 Ground
Old 04-03-2018, 9:14 PM
For the CDM Series:
Pin 3 is PTT commonly; pull to ground to activate.
If you're thinking of TX- as TX Audio -, tie it to CDM pin 7, ground, and tie to 66 block pin 28.
Repeater-Builder's page on CDM accessory connector.
Motorola CDM-series Mobile Radio Accessory Connector
Pins 6, 8, 12 & 14 are the available channel steering inputs (progammable in the CPS).
Old 04-04-2018, 3:43 PM
So just to make sure I'm understanding it correctly, I can tie pin 7 to multiple connections?
Old 04-04-2018, 5:28 PM
Yup, since it serves as the low side/return/ground for all the signals; PTT, TX Audio, and RX Audio.
Old 04-04-2018, 6:14 PM
Okay, does this look correct?
Old 04-04-2018, 9:51 PM
Looks good from here!
A suggestion: Make an intermediate junction point between the CDM accessory connector and the punchblock; maybe wire an RJ-45 jack close to the 66 block, and another one close to the radio, and connect with an straight-thru Ethernet cable. Each jack will give you screw terminals under the cover to test at, and you can separate the connection at either end.
