Mounting a Yaesu FTM-3200DR In a 2011 Hyundai Sonata Ideas?
wolverine
Cincinnati, Ohio
Does any one have any idea's as far as mounting a Yaesu FTM-3200DR in my 2011 Hyundai Sonata?
Special mounting idea's and bracket mount idea's?
bharvey2
Is a separation kit available for that radio? What amount mounting the face in what appears to be a cubby hole under the climate control console?
k6cpo
San Diego, CA
The FTM-3200DR does not separate. It's a single unit. That, and the fact it's single band (2 meters) and doesn't have all the GPS/APRS, Wires-X, etc. of the other System Fusion® radios is why the price point is so low.
As far as mounting is concerned, you have to ensure the radio has adequate ventilation. With a max power of 65 Watts, it can probably get a tad warm. The other consideration for mounting is do you want to drill holes in your dash or not.
mrweather
If you don't routinely carry passengers maybe consider mounting it to the side of the console.
If that doesn't work and you really want a Fusion radio, you might have to spend a bit more and get the FTM-100DR since it gives more mounting options.
Project25_MASTR
Millennial Graying OBT Guy
Texas
A seat gooseneck seems to be the no hole solution.
If the radio had a remote head option id recommend a Panavise InDash mount coupled with a ram pedestal which still may be an option.
russellmaher
KC1ANC
Enfield, CT
I would second mrweather's idea of mounting it on the side of the console, so that the unit faces upwards so you can see the screen and can work the controls. The speaker is located on the front panel instead of the bottom so the sound shouldn't be obstructed.
I have used this location for mounting radios when there are no locations on or under the dashboard to mount them. This spot has worked fairly well for me but it could prove inconvenient for someone sitting in the passenger seat. I would use the measurements of the radio to approximate how much space will be needed in that location.
I have an 06 Sonata and agree that there isn't an enormous amount of space there.
Good Luck...
Russell
