NMO brass nut
scottyhetzel
Palm Springs Area / OrCo
Hi All,
I have a roof mounted antenna on my truck...the brass nut keeps coming off with the antenna (Austin spectra) . I have cranked down on the nut before.. Any ideas to keep it in place. Anti seize the treads of the antenna?
Project25_MASTR
Millennial Graying OBT Guy
Texas
I'm not familiar with how the Spectra mounts. If it mounts like the 500c then I would suggest backing off the center pin tension on the antenna side. Another thing that can be done is a little blue locktite on the brass ring (it's just supposed to be snug).
SCPD
QRT
Virginia
Is the small neoprene ring that seals the brass ring still in there? It seems to provide not only a firm water tight seal, but provides enuff friction to hold the mount in place when the antenna is removed. Without it I have found NMO mounst becomes worthless.
.................................CF
N9JIG
Sheriff
Moderator
Far NW Valley
I agree with C-F, check the ring. Also make sure you use a flat NMO gasket between the painted roof and the base of the antenna.
You might also want to try a little conductive gel on the threads of the antenna where it contacts the brass ring.
scottyhetzel
Most gel is non conductive, especially dielectric grease.. The only conductive grease is that gray grade for aluminum wire . What grease were you thinking?
scottyhetzel
I just serviced my NMO, cleaned thread, added a little blue locktite to brass nut. Used a Tiny bit of anti-seize to the antenna threads...there was not an antenna gasget like the one that came with my new Larson antenna....need to add one. Thx for everyone's help.
