Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 04-08-2017, 3:37 AM
Default Request advice for 2000 Chevy Suburban Install
I just bought a 2000 Chevy Suburban and I want to mount a switch box, siren and eventually a 2M radio. I have an idea but I am not sure how to go about it yet.
I am looking for mod ideas and what type of material to use. The 2000 model has a cassette deck in the middle console. I have removed that. My thinking is to modify that area of the console. Not sure if the switches or 2M rig will go there. I do want to try the siren in the middle though.
Here is a picture.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 04-08-2017, 12:32 PM
mmckenna's Avatar
My brother in law mounted an Icom F621 UHF radio in the cassette deck slot of his 2000 or so GMC pickup. Worked pretty well and looked almost factory. Wish I had some pictures of it.
Old 04-08-2017, 10:06 PM
sefrischling's Avatar
This is how I have my radios installed in my 2002 Yukon XL (same as a Suburban). Works quite well for me.
I Listen To Stuff For Work ... Which Is Convenient Because It Is Also My Hobby
Current kit: 346/396/996xt, Yaesu FTA-550, a few UV-82s, some Moto Astro Sabers, XTS3000 & XTS2500s & a few Minitor Vs
Old 04-08-2017, 10:18 PM
If you could tell me what you did to modify the middle section for those radios you will be my new best friend lol. This is exactly what I want to do but not sure to go about doing it.
Old 04-08-2017, 10:50 PM
I used a sawall, cut out the front, then installed to supports, of brackets from True Value on the inside, mounted to the plastic shell. From there I secured the DIN box to the brackets, secured the radios in, and a friend of mine cut me a piece of black plastic to cover up the bottom hole. The top hole is where the cassette deck was, I just cut it wider and slipped the 996xt in, the bottom was where that storage space was, which I had to entirely cut out. It is not as strong as I'd like, but it works. I wish I had shot photos of how I did it.
I gutted the whole inside, rather than remove it. I just took the Sawzall and cut straight into it, removed everything, then worked with the empty shell.
Old 04-08-2017, 11:19 PM
That's what I was thinking. So you cut out all of the guts and made brackets.
Old 04-08-2017, 11:27 PM
Yup. I spent maybe $15 on brackets at True Value. They don't need to be heavy duty at all. There is essentially no weight to the radios. Took me a few days to figure it out, but once I did, it only took me 2 hours or so to get it all together. I spent more time cutting , to ensure I wasn't destroying the shell, than I did assembling.
Once you gut it, it will feel weak and wobbly. This is why you need to secure it with brackets attached to both sides of the exterior walls, to make it stable again. Flat head goes on the outside of the walls, facing into the vehicle cabin. I didn't think that through initially , it was easier to have the nut on the exterior, but forget how it looked, my daughter kept whacking her ankle into it some how in the passenger seat.
Old 04-08-2017, 11:29 PM
This is the switch box and the other is a Whelan siren or eventually a 2m rig
Old 04-08-2017, 11:30 PM
What did you buy for the brackets.
Old 04-08-2017, 11:42 PM
My idea is to reuse my brackets from this jotto desk. Take plastic and put behind the brackets and then find a way to secure everything in place.
Old 04-09-2017, 8:09 PM
The basic, cheapo, galvanized straight brackets and small (single hole per side) 90 brackets. Once you see them in Home Depot or True Value it'll make sense and jump out at you. I really wish I had photographed how I did the work. my apologies.
Old 04-09-2017, 8:16 PM
That's okay. Your pic is the closest thing I have found to date.
