Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 04-29-2017, 11:52 AM
Homeboys-Scanna's Avatar
Default Where To Order Custom Cable Assemblies?
Are there any companies/dealers that let you order custom coax where you can tellem what length, connectors, and kind of coax and they'll make it for you? Antenna Farm used to offer this, but now I guess they're out of business. Now I'm wondering if anyone knows of any other companies that do this. Say, if you want an NMO mount with 20 feet of RG-8X and a male BNC connector, that you can order it.
"Copy, 132 and Bush, cover's code 3."
Old 04-29-2017, 12:00 PM
RF Connection Coaxial Cable
Old 04-29-2017, 1:23 PM
n9mxq's Avatar
Coax Cable assemblies|RF 50 OHM|RFID Cables|Custom coax assemblies
Gene
Transceivers, receivers, and SDR! Oh My!
Old 04-29-2017, 3:38 PM
I use tessco
Sent from my SM-G955U using Tapatalk
NYS FF-EMT/ DISPATCHER
APX 7000 / XTS 4000 / BCT15X / BCD 996p2 / BCD 536HP / UNICATION G5 /
Old 04-29-2017, 7:39 PM
https://mpddigital.us
Old 04-29-2017, 10:37 PM
mmckenna's Avatar
You can order NMO mounts with longer cable. Problem is the connectors are not usually installed so it can be cut to length.
One option is to look for the Larsen NMO mounts with the "FME" style connectors. There are two options:
1. The FME jack is on the antenna base at a 90 angle. You install the cable separate from the mount.
2. The NMO mount has a cable with the FME on the end.
The function of the FME connector is that it's a small connector, just a bit bigger than the coax, so it can be pre-installed and routed through the vehicle easily. When you get to where you are going with it, you install an FME to BNC adapter on the end. It's just slightly longer than a crimped on BNC.
Many years ago we ended up with a "pre-engineered" product that had one of these. It was the first one I'd used, so I was interested/skeptical. Anyway, it's worked fine, no issues.
You'll pay a premium for this, but it's not a lot. If you are not comfortable crimping/soldering your own connectors, or just don't have the tools, it's a good option.
Alternately, if you were to tell one of us exactly what you wanted, we could just build it for you.
Old 04-30-2017, 10:20 PM
Antenna farm is back in business...check it out.
You be steppin....I be stomping.
Old 05-04-2017, 12:51 AM
mmckenna's Avatar
I just tried to order something from them, but I got a message saying they weren't accepting orders at this time.
Oh, well, I needed a new antenna like I need a hole in the head.
Old 05-04-2017, 6:32 AM
Default Custom cables
A lot of Amateur radio shops/stores will build custom cables. The one in Overland Park, KS (Associated radio) does....
$.02
Old 05-04-2017, 9:06 AM
jonwienke's Avatar
Originally Posted by KM4RZT View Post
I've ordered stuff from them. Definitely not the cheapest option, but definitely quality materials and workmanship.
