02 Ford Sport Trac NMO mount help please
Tobashadow
Sweetwater, TN
I've decided to drill for a mount in the roof for a dual band to replace my failing magnet mount. I pulled the back dome light and there is a bracket between it and the roof that the light mounts to. I thought about using a Dremel and making a hole thru it just big enough to give the mount clearance. Does anyone else have any experience on this vehicle?
This is my first NMO mount and I'm surprised how tiny the mount actually is.
Sent from my SM-J320P using Tapatalk
crazyboy
NJ
If it will fit between the bracket and the roof you can put it there, no need to get to the bottom side of the mount for installation. I would personally pick another spot though
Tobashadow
Sweetwater, TN
To add to the above if I can see the location and there is enough room above the bracket is there any need to be able to access the back of the NMO mount when installing it because my back window rolls down, about a foot behind the area and I might be able to look under the headliner to see if it's clear. In my understanding the NMO is designed to be installed from on top.
Project25_MASTR
Millennial Graying OBT Guy
Texas
NMO is drilled and installed form the top however, this assumes you have an NMO hole saw (which only goes 1/4" past the sheet metal. Most headliners have up to 1.5" of clearance depending on where you are drilling. Drilling the hole with a step bit or other bit...you'd have to drop the headliner a few inches prior to drilling if you can't find an access where you can keep an eye on bit depth.
nosoup4u
High Bridge, NJ
There is a very old thread on batlabs from a guy who did this with his sport trac, you might want to search there. He had pictures of everything he did.
Tobashadow
Sweetwater, TN
Well I decided to pull the rear dome light and take another look, it seems it was easier then I thought it would be. The rear dome bracket had for some reason a 1/4" hole in the dead center which gave me just enough room to pilot drill it from the bottom then drill the 3/4" hole from the top without touching the bracket. Then it was twenty minutes of fishing the coax and bam installed.
