I'm looking to not reinvent the wheel and seeing if anyone has any experience putting in NMO mounts on newer model big rig tractors like the Kenworth T880 (all fiberglass body). The only factory antenna mounts I'm aware of are CB mounts on the mirrors with coax ran inside the mirror mount. I've had luck reusing the CB mount hole with the typical thick-mount NMO like Laird MABVTO but 1/2" barely fits and puts physical strain on the mount, where the second duplicate install I did snapped the metal off, busting the solder connection and forced me back to the drawing board. There's no rods, grab bars or anything to mount to outside. Some of the other 1" long NMO-to-UHF mounts are way beyond 1" in length and won't fit in the mirror mount. Kenworth rep is no help.
I'm hoping to stick to the mirror, or an unknown purpose-built solution for this. Right angle bracket randomly screwed to the back of the cab is always a go-to, but leaving that as last resort. This is for 5/8 no-ground-plane VHF use.
I'm about to drop a bunch of money on a few more thick-mounts that have stronger-looking bits that broke on the MABVTO, but wanted to try this forum for a last chance. Thanks!
